School me on enclosures please.
I have received confirmation from Teknic that my order has shipped; PM says the mill will ship end-Dec or early Jan. So now I am deciding on the enclosure.
I plan to put the electronics (Acorn, relay board, Acorn Power supply, Teknic IPC5 power supply, a DIN rail mounted 24V Mean Well power supply), and Teknic DC power distribution hub) into a metal enclosure, attached to the mill.
Ideally the enclosure will be dust protected and will have an attachment wall for Ethernet in, wall power in (240 and 120V), and connections to the three motors, e-stop and 3 inductive limit stops. The three motor cables (6 cables) will go through the wall through some opening, but the other will attach to the wall with connectors.
My main experience is with the Avid CNC RouterParts system which has a very nice 400 x 400 x 200 mm steel case and nice connectors on a removable side plate.
I need advice on what enclosure, what size, and which accessories (ie female-to female ethernet connectors, power in connectors, etc) do you recommend.
