- Feb 23, 2016
- 480
@jwmelvin: Why don’t you like your trays?
I wanted them sloped towards the left (the drain) but the front one is not sloped enough. Now they are both spot welded in, so I cannot easily tilt it further. The second reason is that the dual drain system (needed because of the transverse support for the mill breaks the space up in two) seems overcomplicated.
Am tempted to yank out both trays and replace them with one 24x24" tray placed just below the top frame (ie. just below the crossmember that supports the front of the mill). Will see for now how this setup works.
Next phase will add the belows instead of the pathetic rubber sheet that PM delivers it with.
