Made the thingymajig and it was amateur hour I milled the tool post on my lathe and took too much off and the threads poke through. Now I will beg my parents to bring me to Lowe’s to get some screws then cut up old feeler gauges for the shims
Everything I posted is in the scrap bin I made a new crank with a steel pin the pin is a half thou press fit and a really smooth fit with the bushing. My phone died so I did not get any pictures of making the bushing but the is boring work
Made the crank arm thingy but I am really low on metal so I need to buy some bit metal is expensive now but I got a Sandvik scraper blade pre-ground and ready to go but I don’t have much time to make it because of school and chores and machining takes time so it will be some more time
