The replacement gear from Boston Gear arrived today and I can breathe a sigh of relief that it is a match with the original gears. For anyone looking to do this, the Boston PN is L102Y. L127Y would also work, but has a 1/2" bore instead of 5/8". If you're just looking for the specifications to buy from Browning, Leif, Martin or others, you need 12 diametral pitch, 18 teeth, and a 20 degree pressure angle. Any of these will require some machining to make fit, but isn't that the purpose of having a machine like this? I'll document the rest of the project here as I get to it.
