Now that I've got the traverse gearbox working well, I think I should tackle the power cross feed. Like many of these lathes, the key cast into the miter gear is entirely gone. I was planning to broach a new keyway and pin a new key in there and be on my way. On closer inspection, the Zamak gears are crumbling so I don't think this repair would last long. I'm not sure what causes this, but I'd like to replace it with a steel gear.
From the measurements I've taken of the original, it appears to be a 12DP 18T miter gear. I'm not sure how to measure the pressure angle, but all of the commercial ones I've found are 20 deg, so I'm hoping that's a match. Has anyone used a gear from Boston or otherwise and adapted it to this purpose? I know there are steel versions available on eBay and elsewhere, but I'd like to do this myself for less $$$.
This one from Boston Gear is only $26.50 and seems to meet all of the necessary criteria. I would bore the center out to 3/4" to clear the leadscrew and then make a counterbore on the back to accept a sleeve pressed in for the shank where the keyway is. The pair could be silver soldered together or pinned if a sufficient press isn't achieved. Thoughts?
