Here's what I've got done so far...
A few tips: spend some time to smooth up the castings, the slicker they are, the slicker they will turn out. Make sure the castings are oil free, if your not sure, pre-bake them to cook out all the oil and grease and blow the powder on while they are hot. If you don't have any silicone plugs to mask off holes, use a wad of aluminum foil. I found that the cheap ol' manilla colored masking tape works well as it almost falls off coming out of the oven. To clean up the goo left behind, use WD-40 and some #0000 steel wool.
I have to ask what cutting fluid you using.does anyone know if powder coating is resistant to cutting fluids?
Two fluids I use have removed all the chinesium paint from my 9x20 every where its splashed.
Also would any of the castings warp in the heat of the powder coating oven?
Thanks
View attachment 267955View attachment 267956
I believe the chemical in Tapmatic was trichloroethylene. It really was a great tapping fluid. It made a sizzling sound as I was tapping. I made the mistake of using on aluminum once and smoke spiraled up from the tapped hole.Some food for thought:
Trichloroethane(1,1,1,Tech) has been outlawed for years, justifiably so. I do miss it though, in certain applications and still have some on the shelf, although it requires some seriously careful handling. Been using it since the sixties, so a little more exposure ain't gonna kill me much sooner..... And, it does clean metal and removes oils deep in the pores of a casting for painting, &c. There is still nothing to compare.
I bring this up for a couple of reasons.
First off, the really good Tap Magic, the kind no longer available, has this as a component. As well as some other shop fluids that are NLA. But for us old timers, there may still be some on the shelf.
Secondly, there is NO paint, or any other finish, that will stand up to it. If it will turn aluminium to powder, paint doesn't stand a chance. Even powder coating.
Please understand, I am not denigrating the project, by any means. But if you do have some of this on the shelf, painted surfaces are a has-been. I have a Grizzly from the '90s, a G1550 9X20. Tiawanese, rather than mainland China. As good as the paint is, there are places on the headstock where there isn't any. So I'm sloppy when I'm rushed, big deal. The point is, if there is any of this stuff around, the paint isn't.
For what it's worth, when Tap Magic was taken off the shelf, I had a friend sold me several cans. Of the old stuff. Because it works, well. The new stuff don't.
Bill Hudson
