- Dec 20, 2021
- 1,074
I think the engine flush chemicals are designed to break up the junk that forms. Same idea, just purpose made stuff.Last time i used oven cleaner and run water with the engine running till it was crystal clean.
Oven cleaner has sodium hydroxide in it. That literally eats aluminum, I use it to clean end mills with aluminum stuck on. Some warm water and sodium hydroxide, drop the end mill in and in a little while no more aluminum. So, you might want to be careful with that if there's any aluminum in the engine. I know corrosive chemicals can cause stress corrosion cracking in metals. Even window cleaner (ammonia) on brass is bad.
