- Dec 20, 2021
- 1,048
That's an easy one. NO!Is it big enough for all your toys?
They never are! When I built mine, I could drive a U turn inside it. Now you're lucky to zigzag through it and not bang your shin or hip! lol.
Is it big enough for all your toys? Hard to tell from the pics if you're going to be able to double-stack the roadsters and still have room to work. Maybe a lean-to for the motor bikes hiding in the build?
It's not possible to build a shop big enough...
But having a shop is a very fun exercise in "making do with the space you have".
I have an 1800 square foot shop, a 16x16 shed, an 8x10 shed, a 30x30 garage, and a 2100 square foot basement... and I'm considering selling my Yamaha Rhino to clear up another 40 square feet of space...
-Bear
I know, right!! . Different crew (less of them) for the next step.what they only work 1/2 a day ?
Looking good.
So he has the James Bond shop. It lifts up from it's hiding spot, then flips over taking the cars to the hiding spot. I guess you missed that part of the build.Is it big enough for all your toys? Hard to tell from the pics if you're going to be able to double-stack the roadsters and still have room to work. Maybe a lean-to for the motor bikes hiding in the build?
Secret Hideout for Emergency Defense (or S.H.E.D. for short). Don't let's it's rustic exterior fool you...It's way bigger on the inside.So he has the James Bond shop. It lifts up from it's hiding spot, then flips over taking the cars to the hiding spot. I guess you missed that part of the build.
I find this very relatable Creeper seat slalom should be an olympic event!Now you're lucky to zigzag through it and not bang your shin or hip!
Just 2x4 framing? Not 2x6 for more insulation? Pay once rather than keep paying for more heating? or are you figuring the overhead doors will leak too much and outweigh any insulation benefit?I'm going through the process of getting approval for a 28 x 33 (924 sq. ft.) The maximum size allowed where I am. Lots of stupid things in the zoning code.
I want to be able to do some woodworking and mostly playing with my lathe & mill. I've drawn a plan to scale and made scale cardstock machines to test layouts. After each iteration I've taken a photo. I've laid out for 3' aisles. 3 phase tools close together. Most commonly used tools/accessories nearest to where they are used. Welding & grinding furthest away from machine tools & wood storage. Things on wheels so a car can be worked on inside. 16x9 OHD & walkin door on street side. 9x9 OHD & walkin on backyard side. Having two overhead doors on opposite ends will allow air flow thru in the hot summer. A few high windows for some natural light. 6" slab 4,000 psi with #4 rebar 2' O.C. both ways, set on chairs. Sawn control joints. 8" riser w/J bolts to anchor pressure treated wall sill plates. Code 2x4 framing and roof trusses, asphalt shingles, wafer board sheeting & barrier wrap. Vinyl siding to match house. Gutters and downs. Driveway & curb cut. A little bit of sidewalk. It will be interesting to see what the bill comes to. Any guesses based on your experiences?
One of the code restrictions here is no insulation is permitted in garages. I think they are trying to prevent someone from living in them. Stupid! What happens later, after inspection??? Overhead doors are always a leaker. Even with the seals, which don't last very well, there is too much slop in the system. I had expensive OHDs put in my business but the seals failed after a few years. There were rubber seals between each panel as well as sides and bottom. They didn't last. The doors had urethane foam cores. 16w x 14h. I've considered what I can do to make an interior cover for winter, not easily done. Will get the best doors I can and do all the adjustments myself.Just 2x4 framing? Not 2x6 for more insulation? Pay once rather than keep paying for more heating? or are you figuring the overhead doors will leak too much and outweigh any insulation benefit?
