- Nov 25, 2015
- 10,049
Still using mine John, thanksI used a length of #12 copper wire for the pull handle on my original swarf picker. Formed a ~1" loop in the upper end, and used a dab of solder to hold the loop closed.
.By using ~3/8" tubing for mine, it can be used inside the T-slots of a mill table. Yours definitely has a much greater capacity than mine. Nice adaptation!
PS - I've found that the swarf picker can easily be stored ( and kept visible) by sticking the magnet end onto the cast iron housing of the machine tool where I use it most often.
#6 is the worst. You are a lucky man! Buy a lottery ticket!Today, I broke an obviously brittle 6-32 tap, not once, but twice. I only broke 1/3rd of the tap off in the hole, so I chucked the tap up in the Sheckel and re-ground the tip. I was on my last pass, and too much stickout bit me in the azz, the tap went ping! How ya like your tap in three pieces, John? The Kromedge steel was as fragile as an ice cube, so I cracked the broken off piece still stuck in the hole with a few whacks on a pin punch. Nothing but HSS dust poured out. Threads intact, good news. I finished chasing the threads with a less rigid tap and moved on.
Another walk in the park for Mr.Newman. Magically making chicken salad out of chicken sheet since 1970. Had that been me the tap would have fragged my eye and bonded in the hole so tight that the ordinance disposal unit would have been dispatched on fear of momentary thrust in all directions.Today, I broke an obviously brittle 6-32 tap, not once, but twice. I only broke 1/3rd of the tap off in the hole, so I chucked the tap up in the Sheckel and re-ground the tip. I was on my last pass, and too much stickout bit me in the azz, the tap went ping! How ya like your tap in three pieces, John? The Kromedge steel was as fragile as an ice cube, so I cracked the broken off piece still stuck in the hole with a few whacks on a pin punch. Nothing but HSS dust poured out. Threads intact, good news. I finished chasing the threads with a less rigid tap and moved on.
The clench that accompanies a breaking tap can best be described as a catastrophic implosion.Another walk in the park for Mr.Newman. Magically making chicken salad out of chicken sheet since 1970. Had that been me the tap would have fragged my eye and bonded in the hole so tight that the ordinance disposal unit would have been dispatched on fear of momentary thrust in all directions.
Good day in the shop, found my @hman swarf picker upper.I used a length of #12 copper wire for the pull handle on my original swarf picker. Formed a ~1" loop in the upper end, and used a dab of solder to hold the loop closed.
