- Dec 20, 2021
- 1,072
Today was judgement day for the K7M engine. It's not making compression, the starter motor got a good work out but wouldn't start. After thinking about it i decided i'll rebuild it in place. i have one more spare but if this one is stuck i'm sure it will be also. With only 2 hours to spare i took apart everything around the top end and managed to remove the cylinder head. The engine is much cleaner inside the cylinders than the rest of the engine, some one did not changed there oil on time. This engine has 136 000 km and as you can see the valves are like new , i haven't clean them or the pistons. Tomorrow i plan to get the oil pan out and remove the pistons also i'll take apart the cylinder head it needs a good resurface, valves ground, new valve seals. Working on a petrol engine is much easyer then diesel.
View attachment 395715View attachment 395716View attachment 395717
Is it just me, or is there damage to the intake on valve Cyl1, and exhaust Cyl2? Might be lighting in the image...
