My lathe has a very nice factory chip shield for the chuck, but not for the tool post, so I decided to fabricate my own. I've seen several that our members have made, but I was hoping to end up with something a little more compact and versatile. After much pondering with regard to criteria and function, I came up with the following design:
1. It occurred to me that there is sufficient thread exposed at the top of the tool post to attach a holder.
2. I also had two very nice Noga indicator holders that I bought for a project quite some time ago. They have been resting comfortably in one of my toolboxes ever since. I decided one would be an excellent holder for a plexiglass shield mounted to the tool post. So I fabricated top and bottom ends to replace the originals. (I started by attempting to modify Noga's straight end but quickly changed my mind. If I ever needed to use it again as a second indicator holder, I would still have the original parts.)
3. The top end of the fabricated base is drilled and tapped to attach to the holder. The bottom end is milled to a 7/8" hex and drilled and tapped to attach to the tool post. Even though it is hex, it is mounted just barely over hand tight to keep it from slipping. 'Fort-Knox' lockdown is not necessary. The clip that holds the plexiglass is a through-hole on the top face, and 10-32 threaded on the bottom. I used a 1/4" end mill to machine the slot. Since the plexiglass is 0.220 thou, I thought I would need to put a spacer in the slot, but it's very snug without it.
The shield is made out of a piece of scrap clear plexiglass. The Noga body makes it fully adjustable and can be positioned to ride above the chuck shield for close-up work. In addition, it would be a very easy matter to make different size plexiglass shields if necessary. I'm going to experiment with it for awhile, but I suspect I'll end up making an L- or U-shaped shield to direct chips into the cabinet instead of on the floor. We'll see.
Regards
