So, this truck being a work truck still has 'standard' keys. (Standard in quotes, because it's the one with sharp poky edges that have cut my pants pocket!). I think the 'idiot proof' stuff is baked in by default now. It's easier to remove options for low end trucks than add them for high end ones, so the defaults are there.Every car with a transmitter key these days will throw a dash message if you take the key out of the car (ie: in your pocket) While its running. The intent is so you don’t drive away without the key (leave it somewhere, falls out of your pocket, etc) and get stuck at your destination without a way to restart the car.
I'd still be driving my '08 (85K miles) if it didn't develop something in the cab that I was deathly allergic to. Long story there...
With the Eco Mode/Normal mode on startup, it's not that it changes to default. It's that it gives a message asking if I want to return to eco mode, but hides the message before I can respond. Then asking again a little while later. The message center is just idiotic, before you answer one of many questions, it throws up others on top of it. That way you're not even sure what you're agreeing to!
We're in a small town with no local tuners, but I can check around. Thanks for the tip!Perhaps find someone who “tunes” these trucks local to you and see if they can turn some flags in the asbuilt off for you so you don’t get the things that are irritating you going off. I’d give it a go if you were local to me, so theres guys out there that do it. Perhaps even approach the dealer about changing some of the irritating things for you since its still new. They probably won’t touch anything safety system wise, but may be able to change/turn off some things for you.
Hesitant to make too many changes, as it's still so new, tho...
