POTD- PROJECT OF THE DAY: What Did You Make In Your Shop Today?
Used up some junk to make some tools...
We have multiple manifolds of sprinkler valves of assorted styles.
The ones with the screws on top are preferred but we also have some of the type with a screw on cap.
Those can be a bugger as over time they get stuck and combined with tight spaces difficult to grab with anything.
What to do...
If only we had something pipe like that was about the right size.
Went digging through the scrap area where we kept the remaining parts from old radio antennas we scrapped to make wind chimes and we found the perfect junk.
These had a cast part that was between the ground radiator and driven element, and it has a protrusion on the side with a 3/8 hole for the folded element.
Just a bit smaller than the ring, a couple passes in the lathe fixed that.
Had to open the center for the valve to fit.
How to interface, the ring has 12 bars, thescrap had 8 holes, correct size for 12-24 screws of which we had a supply of from our rack work.
Tapped the holes and trimmed 4 screws to allow them to only stick through about 1/8 inch.
It fits perfectly.
Used a file to make the round hole in the protrusion square for 3/8 drive o an extension and ratchet works.
First one was for the diaphragm side, that one is critical to get tight.
The anti-syphon side is slightly larger, but the source material (we have a few) was thick enough to allow for more material to be removed for it to fit.
Had to open up the center and drill new holes to make room for the cap.
This is for 1 inch valves.
They loosely fit the 3/4 inch ones too.
No more busted knuckles...
Sent from my SM-G781V using Tapatalk
Okay, will try this again, as I'm back home, and and on the newer computer. Text from last attempt:
Made some progress on my rolling work table. Still have to use cold bluing solution on the removable backsplash, and the frame, and then seal it with satin poly. Think I'm going to leave the top. Just sprayed some WD 40 on it for now. On a three day mini vacation in Glenwood Springs with my wife, and found a heavy duty three drawer unit that was designed to go under a desk, on FBMP for free. Will be tarting them up some, and maybe try my hand at some pin-striping on them. Have had a set of striping brushes in one of the toolboxes for a few months now, and this would be a good excuse to give it a shot.
Will most likely finish up the gun bluing on the frame, backsplash, and the tray today. Tomorrow will be back on the lathe for a few days, and then we'll see about getting the drawers installed on the bench. The ones I just picked up will reqire a little slice n' dice on the cabinet to get it to fit. Cheers, Mike
IMG_20220917_095226806_HDR.jpgIMG_20220917_095233427_HDR.jpgIMG_20220917_110018844_HDR.jpgIMG_20220917_120728802_HDR.jpgIMG_20220917_124931739_HDR.jpgIMG_20220917_124950396_HDR.jpg
Fantastic looking table Mike!
Today was a very busy day. From work i stopped by the tool/flea market and found and bought this small generator. looks like it's been dropped and broke the fan but runs and makes power. With the power crisis it should be useful. Next on the list was the little niva it needed a check up i've found an oil puddle under it. I top up the front diff it is leaking and made the undernight oily. I did an bolt check everything is tight, i did gave it a wash and while i had the pressure washer i washed couple of wheels in prep for painting.
IMG_20220911_114934.jpgIMG_20220911_114944.jpgIMG_20220911_115012.jpgIMG_20220913_185110.jpgIMG_20220913_185145.jpgIMG_20220913_194850.jpg
