- Oct 6, 2024
- 24
Hi all, Maybe this is a silly question but im not 100% sure of the answer as i am new to all this.
Yesterday i got to the point of tackling the headstock of my atlas 10f lathe. There is a collar that holds in the spindle and preloads the bearings. There is supposed to be a set screw with a little bit of brass underneath to protect the threads. Both the set screw and brass were missing and mr bodge and bugger it used the hole to knock the collar loose with a drift and elongated it to the point that i had to do the same to get it off.
Question is can i drill and tap another hole in the collar or does a set screw hole have to be in a certain place to work. (i did warn you all it was possibly a silly question) or have i got to try and source a new collar?
second question is what size do i need or again does it not matter with in reason?
Many thanks
Many thanks
