Are you responding to me (the OP) or to Dabbler?
KB58 - I was trying to date TonyBen's lathe. TonyBen's lathe is definitely from the 90s, no matter when the motor was made - as I said the stand didn't become available until that time. I was also answering the question about lubrication that was posed.
also to kb58 - Glad you have the seals. Let us know how it was to disassemble the headstock, as many of us have the same problem.
to TonyBen: Your carriage and Apron need to be taken apart, adjusted, lubed (maybe some small repairs) and reassembled. Sounds like yoiur backlash adjustment isn't right, and your main carriage gear is slipping out of contact. Both can be fixed easily.
General: Unless you have a very large reserve of $$$, you will have to bite the bullet and disassemble, clean, adjust and sometimes repair your lathe or milling machine. Some guys avoid this by buying new, but after 30 or so years, they still need maintenance. In the case of the OP and TonyBen, their need is a little more urgent than most.
TonyBen you have a fantastic hobby machine - don't let it go! You have some hours of pesky maintenance, sounds like long overdue, but I've done very accurate work, both large and small on my 12X37. My only beef is with the thread-on spindle. i strongly prefer the d1-4 spindle, hence the new lathe. Personally I wish I had the factory stand, despite the fact I made a very surviceable stand for mine.
{rumour has it that I also like to repair machines and get them back to factory condition...}
