Hello,
When using my Regal 10" lately I'm getting a very poor surface finish. The work is aluminum, I'm using sharp HSS tools, the diameter of the work is about an inch, and the speed is set to 350rpm. I'm taking a light cut and using the slowest feed I can (224 turns per inch). Unfortunately, I keep producing an unusual helical pattern on the surface of the work; you can actually feel the gentle peaks and troughs of the helix with your finger.
I'm fearful that this may be the result of worn spindle bearings, although I can detect no movement in them, even if I use a 4/5ft wooden leave under the chuck. Despite being old (1940ish), everything seems solid to me and I can't feel or see any untoward movement during operation. Nor does it seem particularly noise to me in use; the bearing seem quite (although the front set do drink a bit of oil), and there isn't much noise from the gear box. The motor does hum a bit and produces a little vibration, but I don't see how this can translate to an undulating finish unless there is excessive play elsewhere. Does anyone have any ideas to what the problem is likely to be, or how to investigate the cause?
You can see the pattern in the photo attached (I've altered the contrast a bit to make it more visible).
Pete
Pete
