- Jan 25, 2022
- 129
I noticed an odd thing while using the quill DRO and fine spindle feed.
Whenever I changed direction and moved a few thousandths the DRO reading wouldn't change. The quill (and handle) was moving visually.
A dial indicator on the quill showed that the DRO was missing about 3 to 4 thou of movement.
Then I found that if pressed lightly on the DRO case, the reading would jump to the expected reading. Which is weird, since I don't think there is anything mechanical in there.
The effect is most noticeable when lowering the quill after raising it.
New-ish battery, DRO components firmly attached.
Anyone experience this, or similar?
Speaking of batteries: the DRO defaults to metric after power is lost, as in a battery change. I learned this the hard way in the middle of a milling operation :-(
K
K
