PM727V Z-Axis Crank Difficulty
CKel44
Nov 3, 2020
11
Hobby-Machinist / PM727V users: I've been using my new PM727V several times now and was noticing difficulty in raising the headstock using the crank. It seemed that way too much effort was required to do this and it is very noisy/notchy. I've attached a video if interested.
I removed the rear cover and inspected both bevel gears and the Z-axis lead screw. All were dry or so lightly lubricated that I could not actually tell any was present. I lubricated the gears and leadscrew which helped slightly. I also noticed very tight engagement of the bevel gears with absolutely no play. I don't see that there is any adjustment for the bevel gears if that is the problem.
Has anyone noticed these problems? Is there a fix? Please correct/advise me, THANKS!
Craig
  • VID_20201228_103411613.mp4
    18.2 MB
You should be able to remove the crank and housing cover and do something to allow more gear lash, such as facing some material off the back of the gear or it's thrust bearing surface. Take it apart and take a picture of the gear assembly and post it for further comment.
THX benmychree, I just checked the diagram of all of column components and the cover is a lot more than just a cover. It's actually called the 'Z-axis crank base' which the bottom of the lead screw goes through. It looks like disassembly might have to be top-down. There are, however, 2 taper pins in the crank base/cover that I have no idea what they do. Maybe Precision Matthews Technical will chime in here.
As a note, I'm a bit reluctant to completely disassemble the headstock column of my brand new mill...
Yes, you should not have to do this yourself, call the company first.
You might be able to make a spacer or gasket to move the gears further apart slightly. Sometimes a slight adjustment to the factory build is required. A piece of thin cardboard or fiberboard might do the trick
-Mark
There are 2 setscrews on the crank handle plate. Possibly for adjustment.
-Mark
THX Mark. I'll look at it this weekend, but as I mentioned earlier I'm reluctant to tear into a brand new machine. It should work properly for for at least a few weeks after purchase!
THX KevinM. Those are taper pins mainly used for initial plate placement, but I'll take another look at that.
I've contacted Precision Matthews about this and will let you know their reply.
Craig
Yeah, I noticed that yesterday when cranking up the spindle. My handle was loose when I first got the machine, when I tightened the setscrew the crank got really stiff. I loosened it up some and haven't pursued it any further.
