Ok, so from the tech guy over at PM, i used a precision square to shim the column straight, as much as i can anyway. Its within .001 vertically over 7" in both the X and Y axis.
Here comes the part thats really eating at me. After all the careful shimmimg it took.025 in the X-axis and .005 in the Y-axis. So then i indicated my head into my table to .0005 over 14" using a precision ground 123 block. Sounds like everything should be square right? Wrong! I raise the head up 3" and tighten the Z-axis clamps take a reading and sure enough i still measure .0075 off. So, i raise the head to 6" from the surface of the table and once again tighten the Z-axis clamps. Took a measurement and now its .015 thousands off!!! I did exactly the procedure that the tech guy told me. Yet i still have the same results as before. Below are the pics i took quick before calling it a night. What should i do about this????? Yes i know my indicator isnt a browne & sharpe, but since i dropped it while trying to get this machine fixed its all i can afford for the time being, plus i got the same exact readings with my browne & sharpe so i know its atleast accurate.
