- Jun 25, 2020
- 26
Hopefully the bigger thumbnails are working better for people. If not, i can just throw them on here as attachments.
Slowly have been cleaning up this enclosure box. It's funny, every time i do something like this, i grossly underestimate the size of enclosure i need and the time it will take to wire it all up. But I'm just about done all all i need is one more encoder and motor cable pass throughs and it will be done until the motor upgrade.
I was hoping just some standard14/3 cable would suffice, but that motor controller is throwing out some crazy noise so i need to source get some shielded cable for it. Making a plasma table for a friend in the past, i knew exactly what it was so tracking down all the weirdness was pretty easy. the steppers do not have shielded cable as of now, but everything that carries a signal is choked in the enclosure and drain wires have already been routed. So if issues pop up with those, it should be a quick fix.
As i didn't have time to get any steel to make a stand yet, i figured i would start on the motor mount. Didn't spend too much time on modeling everything, just enough to get this and a spindle lock done. But just looking at it, it appears that the head extender will be moved up on the priority list if i ever want to add a pneumatic cylinder to this.
Roughly 1.85 from the center of the drawbar to closest point of the motor with it backed up almost touching the ways is not much to work with. This may be a long shot, but does anyone have a decent cad model or dimensions of the mounting holes for the head that I can have? i really don't feel like taking it off again to get them.
EDIT: for this guy on youtube who has done some pretty extensive mods on his PM30.
Battle Resistant Outfitters YouTube
On one of his videos he includes a 360 file for a head spacer which I had someone convert to a stl so I can open it in solidworks. this channel was a good find even though some of the upgrades like the 5hp motor is overkill I feel, but he does fully admit that.
