- Apr 24, 2021
- 462
What is schs?Mine wasn't like that. I would say first remove the SHCS & check to see if it's bent. Hopefully it is as that's an easy fix. If it's not check to see if the counterbore is flat at the bottom. Worse case scenerio is the threads being tapped crooked. Not sure what you mean by "I tried taking it off and spinning it around the other way, but it won’t thread that way".
I would ditch the SHCS anyway. I got tired of using a hex key which wasn't a big deal since it's the same size key that I use for my compound. I put a multi-position handle on mine, so much more convenient & quicker to use. You could easily make one but I choose to go with an adjustable handle so it can be moved to any position I want when locked if it ever gets in the way.
