- Apr 24, 2021
- 467
I have a pm1236 lathe. It leaks oil, the leadscrew locknut was loose, so it wouldn’t cut threads in the same spot even when engaging half nut according to proper thread dial/lead screw location. Precision Matthews was no help and blamed these issues on me being too picky and operator error, even when sent videos of the proper half nut engagement. Main reason I got upset with them was because they didn’t say check the leadscrew lock nut ever. I spend more time fixing this 6000 dollar junk than running it.
Now I have a new issue. The 1-3 speed selection won’t budge. There is so much slop in the 1-3 gear set, the locking key, the arm that pushes the gear set, and the gears on the speed selection knob itself.
I don’t even know where to begin with what should or shouldn’t be replaced, but it’s out of warranty. I’m not so sure that they would have honored it anyways. They would probably tell me I’m not pushing hard enough, or the gears aren’t lined up, or it’s a Chinese machine. I’m hesitant to even call and ask for parts because I was a jerk, and I don’t want give anymore money to them, but then I can’t even get this running. The reason I complained on the beginning about the quality is because I worried that the machine would fall apart much sooner than a lathe should. Now it’s 3-4 years old and that’s clearly going to be the case.
I can get the gear set to move, but only with gear head lid off lining up the gears perfectly and enough force that it will eventually create more slop and potentially shear the rod on the knob and wear the sides of the gears down. It has always been very picky and had to be lined up perfectly, but now it is flat out seized up, and the gears are rubbing and making new noise when running on b-2. When looking at the 1-3 gear on the spindle they are crooked and have alot of side to side play. Also I believe there is a missing pin, but it wasn’t there when I got the machine either.
Someone that knows these machines please let me know what I should do to fix first. My thought was to replace the entire 1-3 speed assembly, including the knobs, arms, spindles, gears, and bearings?
