Does anyone have a part number for the filter circuit board, or know where I can buy one? The wiring diagram just states "filter".
New to the forum. I bought this lathe about 9 yrs ago. The electrical problem I'm having is when you hit the on switch the readout will read 6300 rpm for a second or so, then go to zero. The motor won't run. If you turn the spindle with the switch on it will register the rpm.
I swapped in a new speed control board and adjustable resistor with no luck. At this point I thought I would just start replacing things.
Also looking for a replacement brass "block" for the cross slide. Quite a bit of play in the block.
Thanks in advance for any help
