Has anybody had a problem with a PM1030V tripping breakers when first turned on? I originally had this machine on a 15 amp circuit shared with other things in the garage such as lighting. Today I put it on a dedicated 20 amp circuit that has an extremely short run from the panel. I was surprised to see it trip this as well. This never happens with the machine running. It only ever happens when first turning the machine on.
I have a lot of electrical consumers in my shop and never have trouble with false trips ever so I have confidence in the supply side and reason to suspect the machine.
I will admit to finding the DC motor control on this machine slightly odd the way you have to turn it on then turn the pot down to minimum speed in order to get it to rotate. I wonder if some aspect of the controls create some initial high current condition.
