Hello I have a PM-940V that ready for wiring. I've read other various wiring threads. This machine has a VFD on it. On the side of the machine it has a 3 wire plug that's labeled L, N,PE looking these up this tells me
L=Hot
N=Neutral
PE=Earth
The basic schematics that came with the machine are pretty much useless. This 12/3 wire cord coming outside the box is telling me 110 volts. Reading the online pdf for the Delta VFD it says power to the L1, L2, and Earth the machine already has two black wires on these inputs and I cant believe that this 12/3 wire has the capability to output enuff power run this 3 phase motor.
I've attached a photo of the back of the machine if it helps. The cord outside of the machine states 500 volts and runs to the on off switch.
L=Hot
N=Neutral
PE=Earth
