Decided to just go Acorn after some more weirdness. Pulled the Nmotion and its power supply. Had enough room to put both the Acorn board and relay board in its place. Used some 1 in nylon spacers and 6-32 screws. Also while I was at it pulled the cabinet off the column and relocated it to the wall. Ordered some wire and nylon coated steel conduit (Electrotek on amazon). Will try and get some of it rewired this weekend. Also thinking about putting the power switches on the front of the spindle , purchased a NC E-stop as well to convert over to all NC limits and homes. The control box arm may get re purposed for mounting my laptop.
View attachment 289159View attachment 289160View attachment 289162
Still having problems getting the manual Z axis bracket off. The upper thrust washer won't come down any further and so I can only lift the Z ball screw/motor assembly so far. Any help?
Hi, I am stuck in the same spot you were when you posted this.. I'm trying to remove the manual Z axis and crank, but scratching my head... Looks like I need to remove the large locknut at the bottom of the lead screw, correct? Doesn't look like a regular socket works, correct? It needs to be a spanner pin type socket? Any idea what tool removes this hard to reach (or see) locknut?
