PM 728VT one-shot oiler leak
I've noticed that the one-shot oiler reservoir slowly drains, leaving a puddle on the floor. The owner's manual doesn't have a parts breakdown for the pump, but there's probably a leaky check valve or similar in there.
Anyone have experience with this?
thx
K
I noticed this after a while on my 935. Thought about it for a bit and then installed a simple valve on the output of the oiler pump. Open the valve, give the oiler two or three pumps, and then close the valve. Simple, and worked very well.
Follow up on pump issue:
After blowing out the check valve, I re-plumbed it to raise the outlet above the reservoir level. Used the original fitting with check valve at the top so I could connect the original piping.
Should prevent draining out by gravity with an open check valve. Crossing my fingers I don't some siphoning :confusion:
I am going to do this to my 728. Great tip.
What size pipe fitting does this oiler use?
that does not stop the siphon effect unless you put a vacuum break in the high spot (you do not want that), you need check valves.
Suspect you are correct, and my plumbing might be for nought. I put the check valve back in (after blowing it out and verifying it worked).
PM also sent me a new valve, so I have a spare.
