Yea he is right, IF you dont have to move the head. But if im running a end mill, then have to switch to a drill chuck, guess what i have to lift the head which means i loose zero. Unless indicate the head in everytime you move the head the zero will shift. Having to indicate the head in everytime you make a tooling change would be frustrating, and you would have to have a bunch on really long indicator holders to tram X axis everytime. There has to be a fix for this. If i only knew what was causing it. Did you ever figure out what was causing this in your mill or what you did to fix the issue? I have had really good customer servise from PM so far, they are one of the only companies that dont treat me like a idiot when i call them. I have 2 years of machining technology schooling and numerous years in the workforce for machining, on both manual and cnc machines. So, when i call with a problem that means i have already tried everything they are about to tell me. I am hope full i will get an answer or a possible fix from PM. Matt is a great guy so im not worried yet, i just want to be able to use the Z axis without the headache.
