Hello everyone,
I have begun the process of getting my mill up and running. Our shop purchased a PM-940M CNC. Thanks to Gary and his documentation I've been able to get all my axis up and running and I have run the test g.code roadrunner. The table(x,y) and z axis move as they should but, I'm not able to get my spindle to turn on. I've reviewed the documents and I don't believe I've missed any steps or overlooked something. I've tried both M3 and M4 codes to turn on the spindle but, no luck. Does anyone have any ideas or suggestions that I could try to get my spindle turning.
Edit to add - When using M3 and M4 codes in MDI the VFD still has the "FWD" and "STOP" LED lit up. Regardless of command used the VFD is not recognizing the spindle change in direction or allowing the spindle to function.
