It isn't so much that the chuck needs to be in a specific orientation relative to the spindle, it is that it there is a specific way it has to be tightened to get it to work right. There is one side of the chuck that needs to be tightened last, or the entire thing is pulled to one side and it doesn't spin true. This happens regardless of the position on the spindle or the position of the cams in the chuck.Clocking or indexing a chuck on a lathe spindle is pretty normal in my experience. But then I'm just a amateur.
When I get a new chuck I go through the process of finding the orientation that works the best, and then mark the chuck so I can repeat when I am switching chucks back and forth.
It is sort of hard to describe and I am not exactly sure what is going on. But using arbitrary numbers, if I tighten down Cam 1, then 2, then 3, you feel Cam 1 go way farther and cam 2 and 3 don't tighten right. But if I tighten 2 then 3 then 1, 2 and 3 hold it in place correctly and Cam 1 can't pull it out of position anymore.
It definitely isn't right, but I don't know what cause that to happen so I am not sure how to even begin trying to fix it. The 3 jaw and face plate that came with the machine don't have the same issue. Based on the blue transfer, I am thinking it isn't sitting quite flush.Like I said, I'm no expert, but that doesn't sound right. My chucks sit flush on the spindle and all three cams tighten to about the same spot (depending on how much torque I give 'em) every time. To me, it sounds like you chuck is not sitting flush?
By not spinning true do you meant off center or not parallel(tilted) with the spindle axis?It isn't so much that the chuck needs to be in a specific orientation relative to the spindle, it is that it there is a specific way it has to be tightened to get it to work right. There is one side of the chuck that needs to be tightened last, or the entire thing is pulled to one side and it doesn't spin true. This happens regardless of the position on the spindle or the position of the cams in the chuck.
