@erikmannie I'm late to the discussion (I think I've read it druing it's early posts) my apologies if I've repeated another post.
I use a machined centre in my 3 jaw instead of a centre in the headstock taper. I just chuck up a piece of steel in the chuck and turn it to 60 degrees. every time I need it again I just re-cut the 60 degree by a few thou. It must always be perfectly concentric with the rotation, unless your headstock is very loose.
This process takes about a minute each time - less time than it takes to remove the 3 jaw chick...
