PM-1660TL
Here I did a chamfer & knurl. I noticed as I was knurling that I pushed the knurling tool into the work and rotated the QCTP. I took this picture after I straightened out the QCTP.
I made a less aggressive cut wherein the toolpost stayed square to the chuck. It turned out much nicer.
I use a dial indicator on a Noga stand to check the knurl tool, and also on the parting blade in, and out to try and be as square as possible to the work.
I imagine that you run the side of the tool holder (using the cross slide handwheel) across the dial indicator & then you rotate the toolpost until you get no variations?
I used a 1-2-3 block against the square face of the chuck, but I like your idea better!
Yes your right, I was hit, and miss on the 1 2 3 blocks working well
I believe it. That is one of the operations where a third arm would come in handy.
I never assume that a tool (e.g. a parting blade or tool shank) is square in the tool holder. It also may not be square relative to the toolpost.
When I can, I like to square up the cutting tool itself. Your idea would work very nicely for this.
There was a bit of a coup here for me today because my whiny neighbor has been watching me set up this machine, & I know that he was anxiously anticipating calling in yet another noise complaint when I started using the machine.
HOWEVER, both the RPC and lathe are so quiet that nobody would ever be able to complain about the noise. I know him well enough to know that he laments this lost opportunity to be able to call the police on a neighbor.
I also have the clamp/scissor type which I have so far reserved for tubing & pipe. However, I will now try them on round stock!
