- Jan 2, 2016
- 1,953
I worked for a company almost identical to Saia, (I drove terminal to terminal). I had to check off the items as they were loaded on the trailer that I took back to the starting point. From what I saw, damaged freight was the rare exception (easily less then 1%). Most of what I saw was like a damaged crate, usually poorly designed, and then often no damage to the item inside.I'd love to see some statistics on how often things get damaged in freight.
Before that, I drove for DHL (Contract carrier for DHL), from a terminal, to a sorting station, and back. At the sorting station, I had to wait for the trailer to be unloaded, and then reloaded. The emphasis was on speed, not care. I bet there was damaged stuff every load. I saw freight tossed across the docks, forks through stuff, stuff crushed, run over, and so on. But since you are talking hundreds to thousands of packages on a trailer, it was still likely well under 1% damaged, But enough that amung us drivers, we all agreed that we would not want to for the terminal having to deliver the packages.
