- Sep 8, 2019
- 4,392
Other topics which could be discussed vis a vid a TL lathe:
(1) if it is the case that your cross slide DRO scale cover is blocking your cross slide lock, how do you go about locking your cross slide? I just tighten the 4 SHCS bolts that form a square around the cross slide backlash adjustment screw.
(2) are you up to speed on what may be a proprietary taper in the spindle nose in your PM-1440TL? Could be a Morse Taper #5 1/2? I wanted a bulky, one-piece dead center, and it was a fun project to make several of these as there were none to be found for purchase online. I used the reducing sleeve that came with the machine as a template.
(3) Speed 4 in my upper gearbox is considerably more noisy than any of speeds 1, 2 or 3 but I don’t care. Is this the case for your machine?
