PM-1340GT on Toolboxes?
@davidpbest has been down the path and thoroughly documented most of the pitfalls you'll likely encounter. I have a much cheaper Bolton 13x40 with their "tin can" stand and will eventually replace it with something like what he did.
Do it once and do it right is my best advice, if you can get a cast iron base I'm sure it will serve you well. Otherwise make it solid from good steel and don't look back....
John
