Hello all!
I am new to the forum but I have been looking for quite a while. I have researched this topic a lot but have not found anything exactly like what I am looking to do.
I am thinking about getting a PM-1340GT (1,100lbs). Rather than using the factory stand I was considering the three toolboxes shown. The center one hangs off of the two side boxes. They would be bolted together as one unit. The casters will be removed lowering the boxes to 35" tall. I would use heavy duty leveling feet in their place. On the top of the two end boxes I was going to weld a frame to fit within the recessed area which will have areas to bolt the lathe...also distributing the weight across the entire top of the box. I could also build a frame underneath if needed to further tie the boxes together.
The end boxes are rated at 1,000lb capacity each, which I am pretty sure is limited by the casters, but I am not positive. They are 175lbs each, so pretty stout. I prefer to not build a total exoskeleton around the boxes, just use the boxes as-is for the vertical.
I have two concerns...First is the total weight bearing ability of the setup. Second is the total height of the spindle. I am 5'10 with an elbow height of 44". I am not sure of the pan to spindle height, but I am guessing about 12.5" (Can someone verify this?). The box is about 36" with the added frame. Total height to the spindle will be about 48.5"...4.5" above my elbow. Too high?
I am using this for hobby and light production.
Thoughts and feedback on the setup?
Thanks!
Thanks!
