- Mar 7, 2020
- 8
I have used the Flexbar it works OK, much better than none. I did develop stress cracks over time. When I installed it on my current lathe it is attached to the cross slide so always covers the cutter. I would look at this thread with the same lathe that also went with flood coolant. Lots of good ideas. I use a water emulsion Koolrite on my bandsaw and it works well, but call them and see what they recommend.
Setting-up the PM 1236-T Lathe
I wanted a system that would allow me to move the lathe without needing to spend a bunch of time re-adjusting it. I agree this system would certainly make it much quicker to drop the lathe onto wheels to move it around. But, wouldn't you still have to re-level the lathe every time you park it?www.hobby-machinist.com
Do you have any pictures of the flexbar unit installed on the cross slide?
