- Feb 14, 2024
- 4
First time poster! I picked up a PM-1054TV Mill and 1640TL lathe which was recently delivered and I am setting up. Unfortunately when I loosened the 4 front bolts on the mill head and tried to turn the worm gear to tilt the head up from its shipping position (while having someone support it and assist) I sheared the worm gear shaft off inside the head, it broke at the weak part in the middle where it necks down.
Now to my first problem, the head is still tilting in a downward shipping position. I know I need to remove the head to replace the shaft and potentially the worm gear(s), I would like to get the head vertical first and use a mill head removal tool i have to assist while using the table. Is there a way to get the mill head vertical without the worm gear? I attempted to test pulling on the head (with 4 bolts loosened) with an engine hoist and it wasn’t moving.
