- Mar 17, 2017
- 20
We need a forum for stuff that does not fit in other forums.
I'm fairly adept at cutting flat plexiglass sheets; worked in a hardware store in my youth and refit plexiglass into storm windows and other frames. I got fairly good at cutting straight lines on flat surfaces. The present issue is my wife is constantly dragging stuff home to challenge my skill set. She found a 6" diameter plexiglass tube with walls about the thickness of a single pane plexiglass that she wants me to cut. If I could support it internally, I would consider trying the band saw slowly; all the other ideas I come up with don't get past the thought stage. Even the band saw idea, I can't decide what blade. I know form experience that plexiglass does not like fast moving toothed blades. I know this is not really a machinist question but there is such a wealth of knowledge here, I was hoping someone has successfully done this. I considering making a hot wire cutter like for shaping Styrofoam but didn;t wan to put that much into it, else she may drag home more. Any ideas?
