Guys dont make me wrong but do you know what is main thing about plasma ? Just split on half ? For me get nice side cut...yes you can do 19mm but what is the result ? Something what you can not use or spend to much time with cleaning and loks like melted Choco bar ..
. Alu max amps and fast do not heat to much , do not change to much structure because one side will be more hard then other , cant use for CNC work and so on . Powermax 45 can do max 10 mm with no bad side cut result but clear up to 6mm
. And that is depsense of type of Alu , for me if side is not cleare then that is not cutting that is melting, then you can use Acet+Oxy instead palsma .
. So waht realistickly Power45 can do ?
THIS is maximum ... 1/4 - 6mm rest is just problem ,please keep in mind that i have power 45 and 105.
We tlaking here about cutting not melting i guess
I will post compare of my plasma when CNC is done ... still busy with project
