- Feb 19, 2016
- 326
Yes, the top is easily pinched by those long bolts, individual bolts cost a little more, but resolves that issues and is a but stronger. I needed to make room for the pulley and cable so it was a needed change. Thanks for the heads-up on the press brake. Ive been looking at the different SWAG versions. I also found this one, which comes fully welded and ready to use and its a bit more affordable. I'd just use it for home projects, not serious industrial use. I think this would serve my needs. What do you think of it?
http://www.ebay.com/itm/112253837443?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
I really like that ebay brake that you linked! Lightyears better than the Swag non finger brakes. The only trade off is capacity as far as length. The Swag is 19" and the one you linked is 12". Personally, had I found the ebay brake before the Swag, the ebay jobbie would be the winner. I also have a Connecticut 24" box and pan brake so....I am covered on wider, light sheet metal which would make that 12" brake perfect for me. I'm not too sure my Swag won't find its way into the scrap bin and the ebay brake find a new home in my shop.
Don't get me wrong, Troy at Swag is very good about customer service and they have some great stuff.
Just throwin' this out there....if you were inclined to build your own, I would be happy to give you the dimensions and tube and bar sizes, etc.
