Pilot Hole for Threading
Spiral point otherwise known as gun point taps are my favorite for all thru holes. Even for a blind hole I will drill extra deep to allow extra room for the chips. If I really need thread to the bottom of a hole then I will use a spiral bottoming tap after tapping as far as possible with a gun tap.
After using a gun tap in a blind hole you can pick out the chips to clean out the hole.
Also why I mark stock when I “obtain “ it. Which reminds me, I need to find a chart of the colors they use to mark rod stock.
I found out the hard way that not all suppliers use the same color code for material.
I found a Whitney I have had maybe 30 years. My brother in law worked in a factory that sent 55 gallon barrrels of bits and taps to scrap. He brought these home.
5/!6 is the proper size for 3/8-16, it is likely that your tap was simply dull, hence the tight fit. Likely it was a carbon steel tap, not HSS and it would not tolerate harder materials.
Well, it started out as a Craftsman.
And since it is just a ball detent that will never have a significant load on it you could even go a bit bigger than the "Q" IF it is still tight, you could try a "R" / .339 or even an 11/32" / .343.
If you have a good tap the "Q" should be fine.
It is rare that you will find a good tap at a hardware or big box store. Craftsman never had good taps.
I have their big set I bought in 1987 IIRC, back when I didnt know any better for working on cars. For chasing threads their fine, for tapping mystery metal, not so much.
Yes, so far that is what my search for charts is showing – glad I either label or mark the ends.
For unobtanium, and Dave having it, you have to remember he is a secret squirrel, or from skunk works....
Try the Guhring tap drill charts they are my go-to for all general tapping since they show the common drill sizes for whatever percentage of engagement you want. I like these better than the online calculators:
I also like to use form taps in aluminum. They have a very well set up chart for that too which is also insanely handy for choosing drills for form taps:
Had the lathe since January, but now have my 1st usable part. Drill arbor for a hay sampling tube. And the Q drill bit worked fine. Thanks.
You know I have a bunch of bags of high quality used taps (Emuge, Yamawa, OSG) for not much money...
