Picked up a little mill finally.
chuckorlando
Nov 24, 2013
1,791
Well I have been looking for a mill for a while now. Everytime I find one it sales. The wife gave me 1500-2000 to spend. I found this old girl a while ago. The guy emailed me back twice. But when I tried to set up a meet, he never responded. Emailed again with my number(he had no number listed) and I never heard back. I see it's still listed a couple weeks later so I throw out another email and he text me.
So it runs ok. The bearings in the head might need replacing as they make a little sound. But the ones in school make more noise then these. The power feed is missing the motor but all the gears are in place and good shape. Power quill works as does the fine down feed. Table moves pretty smooth, but needs a good de gunking. Back gears are fine, reverse is fine. The quill return or tension spring(I assume it's a spring) needs replaced as once you get it going it will continue to travel.
It did not come with much, but with enough. 1/8in to 7/8 collets, BP vise, some big endmill holder I think and a clamping set.
It also came with a power converter I think. I know the guy pluged it in and wrapped a string around the pulley on the gray motor in the pic, pulled it and hit the switch and it had power. I think I will just buy a VFD. The gray motor is a 2hp westinghouse I believe.
1972489_796731673675127_58084702_n.jpg1743531_796731633675131_1490718678_n.jpg1972440_796731400341821_1522937095_n.jpg1779123_796731563675138_1338530591_n.jpg1488104_796731483675146_2036143061_n.jpg
- - - Updated - - -
Poor thing would look alot better had he not tried to clean it up with a angle grinder and doodoo brown paint. But for 1200 all told, I figure I am ok
1972489_796731673675127_58084702_n.jpg 1743531_796731633675131_1490718678_n.jpg 1972440_796731400341821_1522937095_n.jpg 1779123_796731563675138_1338530591_n.jpg 1488104_796731483675146_2036143061_n.jpg 1979636_796731523675142_1601415395_n.jpg 1506413_796731437008484_1793248930_n.jpg 1618556_796751097006518_1780143881_n.jpg 12780_796751080339853_1292141559_n.jpg
Very Nice. Looks like it is 120v? Mine isn't VFD and personally I don't miss it, but then again, I am only a hobbist.
Last ones
- - - Updated - - -
Thanks. No it's got a 220 3ph 2hp motor I believe it is. On the tag it says 230v 420v or something like that
1902961_796751773673117_40341518_n.jpg 1779803_796751850339776_119302659_n.jpg 1901666_796751050339856_1086490324_n.jpg
How old is it?
  • Bridgeport Milling Machine Serial Numbers.pdf
If I am reading it right it's a 59 not 69. 12/BR 42677 the J head is j32477 1hp 220/440v
My BP had very loud bearings when I first bought it. If you ran it at the highest RPM you had to wear ear protection. I could not take the noise. I ended out changing all of the gears in the upper end including the spindle bearings. I spent around the same as you $1,200. Mine was built in 72.
Hope you have as much luck with your as I have with mine.
Paul
Looks like a great find. The fact he pulled the pulley to get it moving, then hit the switch indicates it's 3ph probably 208. Once turning they will run on sgl phase but at less than the rated power of the motor.
I also liked your ingenuity getting it off the trailer and in position.
