- Jun 14, 2014
- 410
Very good buy. Both will clean up great. The only way that either one would be junk is if they were broken.
Thanks for this bit of inspiration. I'll try to finish my "play room".Thanks guys I soaked it in WD40 right away and last night I gave it a turn. It works ! There is some slop in the handle about a half turn before my eye sees movement. The hex nut you put a wrench on is twisted.
Something that will work much better than WD40 for freeing rusted parts is a 50/50 mixture of transmission fluid and acetone.
I've been insulating my barn so I can afford to heat it all winter . When done I plan to work on my mill and both vises .
I restore vises as a hobby & sideline. Below are pictures of a before & after restoration of 100+ year old Reed bench vise that was my biggest challenge. It had been laying in the dirt, behind a barn for 20+ years. This vise was truely locked up. Now it is a high quality shop centerpiece.
So, please do what you can to save that old arn, you'll be glad you did.
Happy Trails!
Very nice hard to believe they are the same vise very nice work ! I will try your mix to free up the base and swivel. What do you use for the clean up process ? I wouldn't think wire brush would be ideal for the machine surfaces ?
I'm a ways off from starting on them but it don't hurt to plan ahead .
