- Dec 15, 2014
- 29
I have BXA and CXA from the guy in Illinois. You might need to clean and lube.
Dan Coleman
Dan Coleman
As far as functionality goes it does not. Nothing wrong with improving the fit but you will always need some play to prevent binding of the worm.I watched the video, BUT I don't seem to understand why the "slop" that he measured would matter.
I watched the video, BUT I don't seem to understand why the "slop" that he measured would matter. Seems like what matters is the movement of the tool holder when the wedges are tightened. My lathe/tool post is Chinese. I wiped the wedges & tool holder sort of clean. Mounted my dial indicator to a mag base mounted on the cross slide. Tightened the holder lever and measured the change. That would be the relationship of the tool to the cross slide, .0003". I repeated the process several times getting very nearly the same answer every time.
Then I tried loosening the tool post, pivoting and returning, tightening. I got about .0003 in the opposite direction. I attribute that to the fact that the "TEE" head of the post that goes into the cross slide is quite a bit thinner than the slot. Probably one of those universal fit things. I could make a new Tee bolt if that .0003" got to bothering me, BUT since it doesn't hardly vary from one tightening to another....
I've not had any problems with chatter or a nub when parting off or facing why worry about .0003" and just compensate for it if you can/need to.
That was very revealing to see the innards of the tool post, thanks for posting. I have an older (offshore) piston style purchased long time ago before I knew there was a difference or advantage to wedge. Its remarkably consistent which maybe suggests I got lucky & build quality trumps style. Its the usual crap shoot. Anyways good job on figuring it out. Unrelated but I liked your spindle replacement vid too btw. Keep up the good work!
Wow all of a sudden I don't feel so good... My PM-1236T will be here in 2 months loaded with PM-BXA junk... As far as I know I don't think I can cancel the stuff... K ima go hide and cry now..!I have found it depends where you buy it counterfeiting is not a crime over there. China’s industry are owned by the Commie gov. So they are all phase II no mater who makes them. Most of the factorys are owned by the Army and the stuff from them is junk. The ones that work with the supplyer/resellers tend to be better quality. The BXA I got from PM with my PM-12x36t was junk, it now has my Alais BXA. Untill you have a really top quality QCTP you will always have problems with registration, finish quality and repeatable tool changes. I know there are some China QCTP that do a passable job, but for the most part they don’t. Least ways the the 4 I have in the junk pile don’t, by buying top quality I only cry once.
Good luck
CH
That post was also from almost 4 years ago. Who knows now. Give it a chance and go from there.Wow all of a sudden I don't feel so good... My PM-1236T will be here in 2 months loaded with PM-BXA junk... As far as I know I don't think I can cancel the stuff... K ima go hide and cry now..!
