Good evening. First let me say, I'm not much more than a beginner. I have enough knowledge to allow me to get into trouble. I have tinkered around and made some things in my shop and have been successful in most of those projects, albeit they probably took me significantly longer than it would someone else with more knowledge and experience.
I have a tailstock for my Monarch 10EE lathe in which the screw for the tailstock seems to be slightly bent and thus does not allow the tailstock to function very well; I can only extend the spindle about 1.5 inches. So I decided to make a new screw for the tailstock. The most daunting part of this process for me when considering this was cutting the acme threads, mainly because I had never cut any before. I had performed single point threading many times, but never had the need to do acme threads. So below is a picture of what I need to make.
I apologize for the size of the picture, I'm not sure how to make it smaller.
Anyway, after evaluating everything I decided I was going to need tailstock support at a minimum and since I had the tailstock for the 10EE tore apart I figured using it was out of the question. I still have my first lathe which is an old Southbend 9A and I have a steady rest and follow rest for it. After some investigating and thinking I decided it might be best if I turned this project between centers. Something else I had never done before, but have seen it done. I found the center of each end of the stock I planned to use and set it up between the headstock and tailstock. Then began taking cuts and went through the process of aligning my tailstock on the 9A. After finishing this I set about to make the stock for the different sections of the screw.
Today I went out and got to work and made a lot of progress...until I ran into a snag. My snag may be the result of my order of operations. My plan was to work on turning down the end of the stock to size that was closest to the tailstock. Then using the steady rest close to the middle for support and using the follow rest I would cut the acme threads. This process went okay. I had to move the steady rest to gain enough room to perform the threading, so it wasn't as close to the work area as I wanted, but everything seemed to turn out okay.
My next plan was to reposition the steady rest over to the area of the threads (maybe not the best plan, but hey, I'm learning). Then I was going to turn down that central disc to size (1"). Then I was going to turn down the last section from the disc area towards the headstock, about 3.5 inches. Then I was going to part it off. This is where I ran into my problem. I couldn't get the steady rest close enough to that area where the central disc is because the steady rest would hit the saddle and I couldn't flip the steady rest around because it has to sit a certain way on the lathe bed. So when I tried to turn that central disc area I got all kinds of chatter regardless of speed/feed and/or tool I used.
I was thinking I had seen someone who was turning between centers take the item out and flip it, but I'm not sure if I can actually do that. If I can, then I would have to take the dog off the one end and switch it to the other end and I fear that would screw something up, but I'm not sure.
The cool part at least, my threading is good, it screws into the tailstock spindle for the 10EE, but....I'm only halfway there with the lathe work and I'm not sure how to finish it. Any ideas or suggestions would be very appreciated as I sit here speculating my next step.
Thanks again,
Rick
Thanks again,
Rick
