Peerless 13 inch 1912 Power Hacksaw
Got one myself. Bought it out of a scrap yard 25 years ago for $50.00. It was driven off a line shaft as it still had the idler pully and switching lever still attached. Have not been able to find a serial plate so I can't date it. Changed it over to a V belt and jack shaft arrangment. The main drive wheel was a large gear. I turned off the teeth and cut a V groove. I use it all the time cuts great and when thru the cut the arm retracts and shuts down. Can't beat good old American iron.
Jack
Jack
I did get quite as good of deal as you. I bought mine for $200. Thanks for the info.
First, Welcome to the Hobby-Machinist!
Have a look at the files here: https://www.hobby-machinist.com/resources/categories/peerless.966/
Specifically this one: https://www.hobby-machinist.com/resources/peerless_6-9-13-inch_power_hacksaw_operating-1-pdf.2970/
I believe some of the other documents labelled as "6 inch" also apply to the "13 inch" model.
-brino
EDIT: this thread might also be useful: https://www.hobby-machinist.com/threads/peerless-power-hacksaw.44510/
Thank you so much! Looked at the links. It makes so much more since now!
Thanks for the photos and info on this post. I just acquired the same version of this saw that needs a lot of cleaning and lubrication. And maybe more once I figure out if anything is broken or missing. And this info helps tremendously! Thank you!
