need to make a weldament out of 316.
found I should use 316L:
There are quite a few varieties of stainless steel available for your production needs. If you’re new to selecting steels, then it might be confusing to tell the difference between them. We’ll take a look at two similar stainless steels, 316 and 316L, and explain the difference, so you know what...
alliantmetals.com
Plan to TIG it. any other special weld instructions?
Need to passivate also, never done this or anything like it. read this:
https://www.carpentertechnology.com/blog/how-to-passivate-stainless-steel-parts
This table is the meat of the discussion. No such thing as easy to buy nitric any more.
Found this on Amazon:
So, is 10% just this offer above 10% in water???
Need to heat to 150, can I just do this on an old stove in a restaurant food grade SS pan?
Other things I need to know??
