Here's what I took from the box:
Three pieces of M2 tool steel, which I can use to make other tools
A bag of stainless screws
A speed and feed calculator (I've been wanting one)
A small double-tapered reamer
A parting blade, broken on one end but usable on the other
A 1/2" & 9/16" wrench, never seem to have enough of those
Two pipe taps 3/8" and 1/2", sizes I was missing
12 TIG filler rods, 0.043" x 36": 5 Alloy 625 and 7 Alloy W
I'm especially glad to get the Alloy W filler rods, which I've been wanting since they can work with almost any kind of steel and are good for dissimilar metals.
I was tempted by a few other items, especially one with the word Starrett on it, but decided to pass them on. I did cull some well-travelled and in my estimation less-desirable chunks of metal, which I will consign to the scrap bucket, in order to make room for some of the stuff I added. Among other things I added a new tool that I made myself, and I hope this will start a new tradition. I'm not suggesting that it should be a requirement, but if you have the time and inclination then I suggest that adding a small handmade item is a nice way to share with fellow tool enthusiasts.
The box had some cracks starting in the corner welds, which I re-melted with my TIG torch, and I'm still learning TIG so the results are not exactly beautiful but it should stop the cracks from propagating. I also put screw inserts in the holes that were missing them, and I used inserts with thicker flanges on the corners where the holes were very close to the edges of the brackets. I counterbored the inside of the top so it would sit flat around the inserts, maybe not an ideal solution but it seems much sturdier now that it has all 8 screws secured.
Since Monday is a holiday, I will get this in the mail to NTHER91 on Tuesday morning.
