- Jul 5, 2014
- 2,847
I ran across Parts Depot while looking for a type 200 power feed that apparently has been discontinued. I found it on parts depot for $216
I've emailed the to confirm it is a type 200 as their picture shows a type 140. I've been looking at other stuff and I can get 50lbs of glass beads trinco brand for $22 with free shipping for over $60.
They also have a acurite dro for $300
https://www.onlinepartsdepots.com/product/dro203-10-x-42-lathe-kit-2-axis/
And this is what they have for air compressors.
Trust pilot has them at an excellent rating.
And yes I do remember the old saying, if it's too good to be true it is.
So anyone else have any info on parts depot? I'm about to pull the trigger on the power feed and see how that goes. If well I'll do the DRO and probably 500lbs of glass beads.
Knee Powerfeed Type 200 - onlinepartsdepots
Item #: JD80M9808200Manufacturer: ServoMfg #: M-9808-200 Technical Specifications:•Brand Name: Servo•Description: Z-Axis Knee Feed•For Use With: Kent 3VK, 4VK & 5VK•Model Number: M-9808-200•Type: 200 Description:•Semi-automated machining on Class 1 mills to 5 hp.•Peak Torque (half-wave series...
EMAX Industrial Plus (Full Package) Silent Air Pressure 175 PSI @ 30 CFM Belt Drive 7.5HP 80gal. Electric Lubricated Piston Compressors with Dryer Bundle Packages - onlinepartsdepots
7.5 HP Air Compressor with 30 CFM Air Dryer, 1 Phase, Silent Air System, Piston Silent Air Piston Air Compressor Engineered and manufactured in the U.S.A. The whisper series compressors reduce stationary compressor DBA ratings by as much as 25%! A noise suppression device was first conceived by...
National Parts Depot is rated "Excellent" with 4.7 / 5 on Trustpilot
Do you agree with National Parts Depot's TrustScore? Voice your opinion today and hear what 11,414 customers have already said.
www.trustpilot.com
